2005-2006 Injector Wire Plug Replacement / Repair Procedures
Hackyman
Nevada
Hello,
I recently replaced 3 of my injector wire plugs as the wires were abraded.
After a lot of searching, and some emails to people who can help identify these plugs, here are the connectors you will want if you are trying to do the same. (The plug is not the same color, but you'll be just fine)
I believe the factory wiring is 20 gauge, so you will want to purchase the appropriate pins for this, to match the wire size you use in your splice.
I removed all harness tape, and spliced the wire inside the plastic wiring bridge, for a cleaner look, and used expanding nylon wiring loom/sleeve. The splice was done with an uninsulated crimp splice, insulated with shrink tube. No solder should be used, and cheaper/junk crimps from home depot should be avoided in all situations when doing respectable auto wiring.
These are the crimps I used. Please choose the appropriate size based on the number of wires (2) and gauge of wire being used (20, ideally).
https://www.corsa-technic.com/item.php?item_id=1018&category_id=64
Here is the connector:
https://www.corsa-technic.com/item.php?item_id=2028
I used hozan p-707 crimpers for the terminals. You can buy them from Amazon Japan much cheaper than I could find them anywhere else. These are a high quality
https://www.amazon.com/Hozan-P-707-Open-Barrel-Crimper/dp/B005SUHPSW/?tag=wranglerorg-20
Reactions: LONGJP2
