My 2005 Wrangler 4.0 with 6 speed manual trans has started stalling out. The engine simply loses power. I've found it stalks once the engine has warmed up and I've had to wait about 20-30 minutes before it will restart. I found, by accident, that if I unplug the throttle position sensor and reinstall it, the engine will start up immediately. Once it restarted I can go for a couple hundred yards to a couple of miles before it stalls again. I thought the TPS was the problem, so I replaced it. But, that did not fix my problem.
The check engine light has been on for a short while due to O2 sensors. I don't yet know if it's related but, when I tried to pull codes, it tells me there is no communication from the ECM.
I'm very hesitant to think my Wrangler is the only one to have this issue. Can anyone give me any ideas what is wrong. I haven't had much time to check things out so, if anyone can give me the benefit of their knowledge I would be grateful.
