195° stant tstat, 18psi stant cap with green coolant. You should be at 210-212 ac off, with ac 220-225. If it bothers you enough run a poison spider louver hood or you get an electric pusher fan
So far, after the flush process, and replacing the after market radiator put on in 2018, with a Mopar Radiator, in 104 heat, your suggested numbers are way high.
I was close to these higher numbers before doing this.
Right now, in motion, 200 to 210 with the AC on in 104 mid afternoon heat is consistent, with it closer to 201 most of the time, 70mph plus speeds and air temps 104+ on open highway.
Driving home from Lake Travis last night 199 almost the entire drive.
No vented hood or electric fan. I just am not seeing that there is a need to do anything other than set the TJ up the way it was designed, and I’m trying to do this as process driven as possible.
I’m seeing an issue when sitting at idle, and a new fan clutch is coming Monday.
But I have direct evidence tracking.
1. Was juts running hot-224 to 230.
2. Changed stat just in case, and flushed it super clean, still ran hot.
3. Changed radiator to Mopar, only change, and been running 20 degrees cooler in motion consistently without fail.
One Jeep, but still pretty direct 1 to 1 evidence.
