I bought the OEM hardtop wiring harness(82208907AB) that only comes with pictures. I figured most of It out. It has two wires that I can't figure out what connector and pin they go into. Picture 24 shows a LB/WT wire going into a 24 pin connector position 2 Is this a white connector or Is the mating wire white? The picture says [WT] [MATING SIDE] My Jeep has a white connector with the appropriate empty slot for a pin the mating wire would be light blue, The second wire BK/WT I installed It into a very similar connector with the appropriate empty slot/pin It mates to a black wire on the other side of connector.Picture 25 shows [BK] [MATING SIDE] On these pictures does the WT or BK reference the color of the connector or the wire color on the mating side?Has anyone run into this before or does anyone have any suggestions? Any help would be greatly appreciated.Thanks
