- Joined
- Jun 26, 2016
- Messages
- 56
Yeah when i turn on the air/heat i smell anti freeze. theres no apparent leaks and it isnt losing coolant. What is going on? i smell it most when the heat is on.
There is an echo in here.
Tell me about it. The VA will have my second hearing aid ready October 3rd.Hearing loss... It's part of aging
I assume you have a lot of tinnitus from Vietnam? I only did 4 years in the Army, but I have that ringing in my ear from time-to-time.
I did 23 years of artillery and helicopter turbine engines. Had several cortisone shots in my right shoulder. When I retired the VA denied disability! I haven't dealt with that bunch since! Still cant hear and had to have two surgeries on my shoulder.
It was the VA who the hell knows! That was also 26 years ago.Why did they deny you disability!? Sure as hell sounds like a disability to me.
Yep in addition to shitty hearing I have tinnitus too. I can "hear" but it's muffled and women's voices are significantly harder to understand due to their higher frequencies. At least lower pitched men's voices are mostly ok for me so long as I'm not also in a noisy room. I haven't been able to hear a drum cymbal in years.I assume you have a lot of tinnitus from Vietnam?
The vent system is probably just carrying the coolant odor out of the Jeep. I can think of no reason you should smell coolant at all in the interior except when the heater core is leaking.Mine does when I 1st turn it on, maybe 20 secs then no smell? I have found no leaks either.
