Need advice. Hopeing i didnt screw myself here. I put an 06 4.0l in my 01. After 04 they changed the intake manifold and some emissions stuff and the cam shaft sensor. I swapped in a new intake and got all my emissions controls hooked up. And then i replaced the plug on my wiring harness to fit the diff camshaft sensor. I also replaced just about everything on the motor except for valves, lifters and the head gasket. So my problem now that im finished is it will start but it takes a couple dozen tries and when its at idle it sounds great but the moment i touch the throttle it will die. Im thinking that the camshaft synchronizer is not doing what my ecm wants it to do. I really dont know. Have a lot of time and money into this project and hope it can be fixed. What do you guys think?
