So the 2000 4.0 dropped a main bearing, and has to be replaced. I found a guy with an 06 doing an LS swap with a good motor and figured that would be a cost effective solution. Its a simple swap, or at least it should be…however, the OPDA and sensor are obviously different. My plan is to find TDC and just swap the assembly. Will this work?
