I wanted a manual as well, but my wife can’t drive them....so an auto trans was part of the negotiation process... I’ve come to like the auto trans, wouldn’t be able to dangle my foot out the door otherwise!That's a great LJR! If it manual I would be on my way out to York.
Is it? Come check it out! They didn’t come with a hole there from the factory. This was drilled for drainage. I knew of the frame issues some had when I was looking for one. I can’t say for sure how it was maintained before I bought it, but it’s been well taken care of since I’ve owned it. The frame looks to have been under coated with something at some point.And here. This factory hole should be uniformly round. It also looks like there are chunks inside the hole.
I don’t drive her much but I may have been out that way, I’m usually in Dover.I think I saw you going north on 24 one evening about a week or two ago. Was in my green LJ. Looks great, I'll spread the word.
I’m in Dover. You still might see me out and about as weather permits. And thanks for passing it along!Surprised I’ve never seen you around York in that! Impact orange LJR was where my search for an LJ started! Then I found my green one and the rest was history. I may know someone interested, I’ll send them the link.
I have a hole there where my factory engine skid mounted. I removed the nutsert to open it up more.Is it? Come check it out! They didn’t come with a hole there from the factory. This was drilled for drainage. I knew of the frame issues some had when I was looking for one. I can’t say for sure how it was maintained before I bought it, but it’s been well taken care of since I’ve owned it. The frame looks to have been under coated with something at some point.
Well, I drilled the hole myself so I can promise you this was not there from factory. This was a tip I learned from all the good people on this forum. It is a 14 yr old vehicle so I can’t and won’t claim it to be perfect but it was clean enough for my picky self. Again...come check it out if you’d like to see for yourself!I have a hole there where my factory engine skid mounted. I removed the nutsert to open it up more.
I'm not trying to dog it at all. I actually like it. Impact Orange is my second favorite color after Midnight Blue. I'm just pointing out the potential areas of concern I see. If I were in the market I would def come check it out. GLWS.Well, I drilled the hole myself so I can promise you this was not there from factory. This was a tip I learned from all the good people on this forum. It is a 14 yr old vehicle so I can’t and won’t claim it to be perfect but it was clean enough for my picky self. Again...come check it out if you’d like to see for yourself!
Amd my mistake on the hole. I went back and looked at the photo and realize that is the rear of the frame not the front.Well, I drilled the hole myself so I can promise you this was not there from factory. This was a tip I learned from all the good people on this forum. It is a 14 yr old vehicle so I can’t and won’t claim it to be perfect but it was clean enough for my picky self. Again...come check it out if you’d like to see for yourself!
