2006 TJ automatic won’t start
ahoward2033
TX
Turn the key no sound click nothing , ignition fuse is good , starter relay tests good (replaced anyway ) , I can turn the starter over manually by jumping from the battery to the solenoid but it still won’t crank with the ignition in the on position ; took the starter relay out and jumped from terminal 87 to 30 in case it’s a transmission position sensor; nothing. I’m down to the ignition switch maybe ??? Any thoughts ???
