I have searched this issue and not found anything similar which seems odd. I picked up a Rubicon Tcase to swap in my 2006 tj x and it will not shift into 4lo. on the table before we put it in and after making sure it had fluid it was hard to shift into 4hi and neutral and would not go into 4lo. So we figured maybe it had to have a load with the drive shafts and everything rolling slowly to get into 4lo. The jeep is completed put back together and a roller and still will not shift into 4lo. It shifts into 4hi, neutral, and back through to 2hi no problem.
I am new to the 241 for sure so if anyone has any tips to ideas of what could be causing this your input would be greatly valued. I am using the Novak shifter cable as well.
