I have a 1998 Sport 4.0 auto that leaks from below the drivers side. Park it over night and there's puddle of red on the floor. New knee and need of new hip stops me from working on it myself. What would it cost for seals and a filter?
You really need to figure out where it's leaking from. There are three likely sources of an ATF leak... the 32RH's input shaft seal, the 32RH's output shaft seal, or from the speedometer gear housing's o-ring seal that seals it to the transfer case. Since it's coming from the driver's side, I'd start first with the o-ring that seals the speedometer gear housing to the transfer case.
The shift selector can leak an amazing amount, and is on the driver's side. I replaced mine w/o draining the trans or dropping the valve body, but it wasn't the easiest job I've ever done.
If you can't get under it at all it's going to be a challenge for you, but my standard recommendation is to clean & dry the entire thing. Then stuff paper towels in & around all the things that could be leaking (bell housing, selector shaft, cooler lines, dipstick, NSS, TCC, pressure test ports, etc). Come back in a few hours and see which ones are stained red, and you'll have a good idea where that leak is coming from.
Ok thank you! I did clean and stuff paper towels around it that’s how I know it’s the selector shaft. So I bought the part already how did you get the seal out without taking everything apart?
