I would just watch your radiator fan to shroud clearance. If you move the back up, the front will go down. I had to adjust my should about an inch. That and the exhaust routing gets really close. I had a new tail pipe made at an exhaust shop to fit. I did not have to do any major fabrication just a lot of moving and adjusting. It was a lot of work, but worth every bit of it.Perfect. That’s my exact setup so it should be fairly bolt in if I go this route.
