04 LJ owner here. I am in the process of installing my pieces together OME/Rancho lift, having purchased the 0-2” Ranchos. I have 32” BFGs and live in MN, so mostly street but I plan on doing wheeling trips too. Have friends in CO who want to meet up in the Black Hills next year, so I want to be ready for that.
I just finished my bump stop check for my shocks on the front and I had .25” to go before my shock bottomed out. I was thinking a couple washers would suffice there. However, I did the tire check and need .75” of bump stop to stop the tire from rubbing the seam where the flare meets the fender.
The rear was similar, except I hit full bump with an inch of shock travel to spare. Still around .75” needed to stop the tire, but the tire only rubbed on the flare, not any metal. Not planning on the relocation bracket.
My question is that it seems there are more than a few ways to solve the problem.
1) Switch to 31s. Expensive but maybe the most logical.
2) add bump stops, limiting uptravel by 1” - just feels disappointing
3) I have .75” coil spacers on hand - I could install those, return the front shocks and get the longer ones and be ok, right? I should be ok in the rear with .25” to spare
4) 1” body lift - concerned this will add a lot of work/mods
I dunno, could use a little insight here. In hindsight I should have just packaged something with Dirk instead of trying to save money by piecing it together myself.
