- Joined
- Apr 19, 2016
- Messages
- 172
I know i've asked a lot about rear diffs but now i have a good rear figured out and about ready to go in so now time to finalize the front and see what i can do with what i have on hand. i know some shafts are made and some carriers but there isnt a lot of selection or information on 35 spline 44 setups. You're all going to say to go with a 60 but i have a hp44 to work with and figured out my whole rear situation and now im finalizing the front diff before moving onto collecting suspension stuff. And before saying that 35 spline makes the ring and pinion the weak point look at the jana 54 kit. I think this would be the best ballance of weight, ground clearance and, as i have access to a few wrecking yards, money.
So other than the auburn ected what dana 44 carriers are made in 35 spline?
Is the easiest way to get 60 outers (needed in place of the 44 outers) to use just to part out a truck front diff?
If not going 35 spline what can be done to make the shafts/u-joints/outers as strong as possible?
