You'll need to raise the entire 3rd brake light assembly, which is fairly easy. I've used 1" PVC pipe cut into four pieces of about 2" in length. You'll need longer bolts. The wiring should be long enough that it won't need to be extended.
There are brackets you can buy to do the same thing, but this will get you the same result for significantly less money.
