New video featuring Newcomer Racing. To me, this proves the 4.0 isn't worth the money for bolts on's: either go with boost, or LS swap lol
Interesting but then I don’t get why the S2000 is a sooo common platform for upgrades…Very few NA engines in history have ever responded well to bolt-ons...
FI engines are the other hand response very well. I recall one of the popular hot rod magazines at the time, perhaps even "Hot Rod" itself, did a "bolt-on challenge". They tested a handful of cars popular at the time, including one of the staff members' turbo AWD Eclipse. It held the record for "HP/$ investment" for a long, long time. I recall one of the worst (in the "follow up" article many years later) was the Honda S2000, where it took something like $900 for +4HP...
the S2000 in stock form never responded well to bolt ons. It was very common for 95% of the aftermarket intakes on that motor to LOSE power on the dyno instead of gain.Interesting but then I don’t get why the S2000 is a sooo common platform for upgrades…
I think it was like the Miata, but with better looks, a nicer interior (even if just marginally so), and "Honda reliability"... a fun to drive roadster and just cheap enough for many to get into. The 9000 RPM rev-limit was also fun. It also had some on-screen time when it was just coming into the mainstream, which I'm sure added to it's popularity (which is also why my dreams of an original 2JZ Supra are wanning).Interesting but then I don’t get why the S2000 is a sooo common platform for upgrades…
The bolt on do very little but the stroker hp would be nice. I live in California though and I have not researched the emission compliance aspect of a swap. I know every year it get tougher. A small LS can be picked up for almost nothing but that would require replacing everything.New video featuring Newcomer Racing. To me, this proves the 4.0 isn't worth the money for bolts on's: either go with boost, or LS swap lol
IMO a reasonably sized turbo on a 4.0 would be tremendous fun Like a solid 250whp, tops. Don't need any more than that. The torque figure at that range would be north of 300ft-lbs anyway.
I agree. My Golen 4.6L stroker with a 62mm TB and stock '97 intake and tune makes 24% more HP and TQ than the stock 4.0L with no other changes on the same chassis dyno. Not breathtaking but since the displacement bump is only 15%, perhaps not terrible either. By the way, don't fixate on the absolute engine dyno numbers. They are NOT comparable to the chassis dyno or even the stock Jeep numbers.New video featuring Newcomer Racing. To me, this proves the 4.0 isn't worth the money for bolts on's: either go with boost, or LS swap lol
Dude, that just hurts….New video featuring Newcomer Racing. To me, this proves the 4.0 isn't worth the money for bolts on's: either go with boost, or LS swap lol
How do you like the 4.6 ? I have been kicking that around just haven’t done to much research on it. Right now I am concentrating on making my Jeep lighter.I agree. My Golen 4.6L stroker with a 62mm TB and stock '97 intake and tune makes 24% more HP and TQ than the stock 4.0L with no other changes on the same chassis dyno. Not breathtaking but since the displacement bump is only 15%, perhaps not terrible either. By the way, don't fixate on the absolute engine dyno numbers. They are NOT comparable to the chassis dyno or even the stock Jeep numbers.
He meant Hemi...Dude, that just hurts….
I do like it. Its stronger than stock, for sure but feels the same (like a jeep straight six). Not a transformation like a totally diff engine. And I really enjoyed the swap. It was my first. Its a very straight forward, bolt in affair. If you need a new 4.0L or just want to get your feet wet with a simple swap, go for it. If you want huge power, then do the V-8 thing. I have dyno results and lots of details on the swap in my build thread(https://wranglertjforum.com/threads/woodrow’s-97-green-tj-moderate-build.51602/page-5)How do you like the 4.6 ? I have been kicking that around just haven’t done to much research on it. Right now I am concentrating on making my Jeep lighter.
Thanks for looking it over. Tuning is one of many topics on which I am uneducated. I‘ve talked to Chad Golen pre and post purchase. He neither encouraged nor discouraged tuning it but said repeatedly it’s designed to run well with a stock tune. He also said on their superflo engine dyno they use a stand alone Holley EFI and 36 degrees of advance. A tuner I know in my area and Ryan Hogan of Flyin Ryan were both willing to work on the tune. But while they both agreed there were likely some gains to be had under the curve, they also thought improvement would probably be less at WOT. They also both said that 36 degrees of advance, while workable on an engine dyno, was not realistic on the street. Ryan further said 26 to 27 degrees was more the mark and he hadn’t a stroker go over 28. I may still ask one of them to tune it at some point, but I really do enjoy the improvement in drivability as it is and so tuning has fallen down my list of priorities for now.https://wranglertjforum.com/threads/woodrows-97-green-tj-moderate-build.51602/page-5#post-973066
I looked at the dyno sheets in your build thread and there is a lot of room for improvement. Timing and A/F is off by good bit. That is probably why you are not getting the results you expected. Timing is low and .94 lamda is more than a little lean at WOT. .94 lamda is 13.9 A/F ratio and it should be closer to 12.5 A/F. The timing is the stock timing tables. The 1st point at 2428 rpm has 18.5 advance and my tune has 23 adv, 2nd point at 3831 has 21.5 adv mine has 31adv and the 3rd point at 4674 has 26.5 adv and mine is 31 adv. Golen built you a good motor, but it is held back by a factory tune. Do you have tuning software? Wideband O2?
PS, with those cranking pressures I would not be surprised if that motor would run fine on 87 octane.
