so can anyone recommend a turbo kit for a 98 tj 4.0? out of curiousity i looked online and only see ebay turbo kits
Is there a reason why you're looking at a turbo vs a supercharger?
Edit: Oops. I quoted an old post.
It's drastically changed, FRP tuning has been doing some really cool things with TJ's and setting records on 4.0's! Even making crazy power with boosted 2.5's!
engine with 10 degrees of timing vs 30 degrees of timing, all things equal, 30 degrees makes more power. detonation is what keeps us from cranking it up, 93 octane allows us to crank it higher than 87 octane... This is common tuning results and practices of 87 vs 93. Yes compression certainly will make more power, but i'm simply discussion a stock engine and incremental gains.
I think my 04 has 8.8 cr. Low compression motors can be over advanced and lose power with out detonation. I also agree with Jerry that too much octane can hurt performance.
Granted, the ability to tune ignition and fuel flow has improved, but isn't power output of a stock 4.0 still limited by its ability to move air through it?
In my old hot-rod days, to increase power on a normally aspirated engine we would replace the intake and exhaust manifolds with low restriction ones, port and polish the heads, enlarge the valves and replace the cam with one that would open the valves farther for a longer period of time.
Granted, all these things would help the 4.0 also, but that's a lot more hardware and work than just a re-tuned ECM. It would be interesting to see a cost/benefit comparison of a 4.0 with all the above modification vs bolting on a supercharger or turbo.
Over time, yes it can. The higher the octane, the slower it burns and the harder it is to ignite. That's what octane does. A higher octane than the engine was designed for cause it to leave deposits behind. True."too much octane can hurt performance" you just told me everything I need to know about your knowledge of engines
Ok doc, you're convinced of all this and nothing being said will change it so I'll back out of further discussions here. . . .
The head is certainly the bottleneck on the 4.0. I would love to see a custom head similiar to what a 2JZ runs grafted onto a 4.0, it would be crazy!
Well, I don't know what 2JZ runs, but there's this: https://www.edelbrock.com/performer-jeep-4-0l-cylinder-head-50169.html
That thing looks like a huge improvement, I've been waiting to see some dyno numbers on these, especially with a big cam and boost.
2JZ has a cross flow head (and is a straight 6 too), having the cross flow head on a 4.0 would be so much easier to work on and allow some nice big long tube headers to be fabricated. I don't have a machine shop or the fabrication skills capable of making that work though LOL
I was not talking about 93 octane. This is from the VP page.
https://vpracingfuels.com/about-us/faq/
CAN YOU OVER OCTANE AN ENGINE? IF SO, WHAT HAPPENS?
Yes you can over octane an engine. Generally you will get sluggish throttle response. Also you may get fouled plugs and deposits in the exhaust ports and headers. When an engine is trying to burn a fuel that has too much octane, the burn rate is incorrect and all of the fuel won’t be used up. This excess usually gets left as a deposit or gets pushed out the exhaust. It is important to match your engine’s needs with the correct fuel.
Translation: I stamp my feet and leave the room in a snit when people won't defer to my superior knowledge and intellect.
Not here. In fact this client is about to get his walking papers. In the 6 times I have dealt with him, he has not once been on time and is rarely less than an hour late. Normally that isn't an issue but the last time he had an issue with the lights being wonky and called me at 7:30 on a Friday evening. I told him I'd be glad to take a look at it and he wanted to swing by right then and he lives almost an hour away.
WTF??? No, not tonight and what kind of an asshole even asks that? Knowing his propensity to be late, I offered to look at it the next morning provided they were here on time. He asked what time to be here and I told him it was up to him, pick the time and stick to it. They were still an hour late. He has been relocated to the miserable user category.
