F
fudog666
Guest
So, I’m assuming that other ppl have had this problem or just didn’t notice. I’m assembling a 4.6 stroker. When I dry fit the oil pan it does not sit flush on the block. It rocks back and forth on the girder that goes from bearing cap to bearing cap. The girder has to be spaced so that the rods don’t hit it but, when spaced ever so slightly w/ washers, it sets to low to allow the oil pan to be secured properly. I could throw the gasket in it and wrench it tight. It might seal, it might not. I’m very particular when it comes to mechanics and this is an issue for me. Anybody else have this problem and if so, what to do to correct it? Also, is the girder actually needed? I’m guessing it’s there for a reason. Any ideas/thoughts??
