A good rebuilt or custom built torque converter in a jeep is just as good as spending too much on a billet one.
I think your misunderstood my comment. I replied to the 5k comment from Blaine, not the billet/10k. I agree with your comment above.
If you don't know how to check the case to see if it is still viable, find someone that does. My guy winds up with bad cases about 1 out of 3 rebuilds.
My rebuilds already cost me 5 grand and that's without a billet converter. I don't need a 10 grand trans in a TJ.
Why? I added one and all it did was become a distraction. If you are competitive racing, maybe but I believe that 99% of the people out there will never diagnose an issue or even know what it is telling them.
Why do you think that jeep removed the sensitivity on the factory gauges?
So I work on airplanes and I can say for an absolute fact when people add more gauges it is and will remain a distraction. I watch the owners install 30k engine monitors on an air cooled carbureted engine that do not have balance intakes and exhaust. Then they freak out of a cylinder head is 10-30 degrees different, or an egt is 40 degrees separate between the 6 cylinders. The lead one guy to an 80k overhaul for an engine that’s was within specs because it wasn’t perfectly balanced. I see it all the time. If they hadn’t installed it, they’d have no perceived problem. Ignorance is bliss in some situations. Why do you think that jeep removed the sensitivity on the factory gauges?
To reduce warranty claims from people who have zero mechanical aptitude. and likely couldn't change a flat tire on their Jeep.![]()
And same thing with a temp gauge that is not necessary
I have a 42 and I'm getting ready in a week or two to change the fluid & filter. Going to add a oil drain plug. Now after reading this what is this temp gauge you guys are talking about? Is it a Stewart Warner oil gauge or something different? Even thinking about a trans oil cooler but I'm on the fence because I don't want to add other things that might leak or block radiator airflow.
Seen on the "do to your TJ today" thread that you have bought the trans temp gauge. Did you tap into the lines or did you install a plug in the pan? I was going to get this https://www.amazon.com/Derale-20561-Wrangler-Automatic-Transmission/dp/B004XOO6C2?tag=wranglerorg-20 but got sidetracked to getting a Bedrug & seatcovers because my wife don't like the smell of the Jeep. If you could show me how you installed the gauge probe to the oil. Thx.
Sure
Right now its on the line out - Blaine said that’s wrong - gives a hotter reading when it comes out of the torque converter that way
He fixed me up with a pan and bung- not installed yet
I’m happy to send a pic later when at the rig-
Or can once I relocate
The thought is sending unit in the pan you are reading the temp of the fluid about to be used if I’m not mistaken.
