I have 2005 with the 42RLE, 120K miles. Was driving home and the converter started locking and unlocking. Came to a stop and took off again and it started off in second, went thru all the other gears but no converter lockup. Pulled a 1776, 700, and 841 codes. Changed solenoid block twice. Fluid was like new. Pan was clean. Now if you clear the codes it will take off in first one time. Once it shifts to second it will no longer go back down to first unless you clear the codes again. Always 700 and 841 codes. Any ideas?
