42RLE Trouble Shooting Guide
2005 Service Manual (L/R circuit is T20 16DG/WT)
P0750-LR SOLENOID CIRCUIT (translates to 1st gear and reverse)
You’d need a special scanner and software to test the solenoid pack, but you can do some trouble shooting on your own.
Though this is a solenoid code, don't jump to the solenoid pack being the source of the issue. It could also be ground, power (including fuse or relay), a wire shorting to ground or a dirty solenoid connector. Something to keep in mind about the 42RLE solenoids is that they receive battery power through the #5 20A fuse and the transmission control relay in the PDC when the ignition is in the ON/RUN position. Any interruption to power or ground will set a code and can also make the transmission act up
Start by verifying that the fluid level is correct. Check with the the engine running, transmission in Park or Neutral.
You can also check that the fuse and relay are good and free of corrosion, even swap the relay with another.
After that start inspecting the wiring harness. In the service manual you want to go to the Wiring section, then Connector Pinouts.
Looks like the L/R wire comes out of the PCM’s 4th connector (on the right), runs to the passenger side of the valve cover, down the side of the engine block and back to the passenger side of the transmission where you’ll find the solenoid pack connector.
The wiring harness is known to rub on the A/C receiver drier as well as the engine block. If the wiring harness is routed behind the coil rail, it will rub against the block as the engine mounts flex.
I would take a real good look at the wiring harness. If you have a multimeter, you can also test continuity from the connector at the PCM to the connector at the transmission.
Beyond the above, a shop can test the solenoid pack. Hopefully it’s something simpler.
