Hello, I've seen some other posts regarding similar issues but nothing exactly like my issue.
The Jeep sat for a couple of weeks and the battery was dead. I put a booster on it and it indicated an issue. I then put a charger on it and the battery got super hot. Went ahead and replaced the battery. Jeep now turns over but won't start. After researching I found there is not 5 volts coming from the ECM on the orange wire that goes to the various sensors or the purple wire that goes to the speed sensor in the tranny. I verified that there is 12 volts going into the ECM. After more research it seemed it was either a short in that 5 volt wire or a bad ECM. I've unplugged every sensor according to the wiring diagram. I also don't have any working instruments and don't see any correlation between that and the 5 volt circuit. All fuses are working except fuse 12 behind the glove box. That says panel lamps. I don't recall ever having an issue with this before. I just want to check everything possible before replacing the ECM. Another option I have read about it getting another 5 volt source and connecting it to that circuit. Has anyone done this? Thank you guys for any assistance!
