I have a 97 TJ 4.0 Auto transmission. 186k miles. After driving in Louisiana in a monsoon rain, I had a terrible sputter and thought it was water in gas. Long story short, it was not. I have emptied the fuel cell, replaced with 110 octane racing fuel, replaced the following items: thermostat with a 185 degree one because it started running on the hot side when sputtering, crank position sensor, both O2 sensors, Throttle position sensor, complete distributor assembly, all 6 plugs, cleaned idle air controller, replaced PCM with a rebuilt one from Flagship One, New Battery, cleaned battery connections very well.
After saying all that, as soon as the engine gets to temp, if you are driving or put it in Drive, it begins to sputter and will eventually stall out if you don't mat it to the floor from a stop. Now, it has gotten to the point where you cannot get over 20 mph from a stop when engine is warm. When it starts to sputter if you put it in Neutral or Reverse, it immediately smooths out. It only does it when in rolls even a foot or two in Drive. You can hold the brake in Drive and run it up to 3000 rpm with no problem, but as soon as it rolls, it sputters and tries to stall out.
Someone please tell me there is a transmission sensor or wheel speed sensor or something that I am missing that could cause this. Makes no sense. Not throwing any codes on a Snap On computer.
Thanks for any suggestions,
Greg T
Greg T
