So, unless I'm missing something, it would appear that there was no ABS available on the Dana 44 for the TJ. I cannot find a tone ring available, and
@Jerry Bransford noted in another forum (late Aug. 2009) that he had to disable his ABS when he changed from a Dana 35 to a Dana 44 in his '97. I'm fine with losing the ABS, but I just bought a full kit of stainless steel lines from Classic Tubes (via 4 Wheel Parts) for a TJ with ABS. I don't know what the difference would be, but there are definitely two different kits available, one for ABS, and one for without. I may call Classic Tube and see if they can enlighten me. I don't want to have to return this kit, as it took 4 weeks to get. If the only difference is actually at the rear axle, I'll just order those lines, or perhaps attempt to coerce the existing kit pieces into fitting. I know the ABS can be disabled, but I assume that's done by removing a fuse or maybe a relay, but would have nothing to do with the actual hydraulic brake lines. But again, at this stage, it's just an assumption on my part. Any help regarding this information (and issue) would be welcome.
And now a question for all you Rubicon owners: Do your rigs have the ABS with the D44s? That might be the exception to what I
think I know. But I then need to also ask, are all Rubicons 4-wheel disc brakes? If they are, then the ABS tone ring and sensor might be mounted in a completely different manner/location than anything I could use for my rear drum brakes. I'd think that would likely be the case.
@Chris,
@Ranger_b0b, and
@ac_? Sure could use an education on this one, guys. Thanks in advance for any help!
