I’ve been working on my Jeep went to start it yesterday but the motor wouldn’t crank there was only a click at the starter from the solenoid kicking out. I checked voltage and my battery holds 12.4 volts. I checked my starter relay switch and it was good. I jumped my starter straight to the battery and still only a clicking from the solenoid but no turning. So I assumed the culprit was the starter I pulled the starter and jumped it outside of the car and the solenoid would kick out but no spinning so I went straight to the auto shop and got a new starter came back installed it and same problem, I can hear the starter solenoid kicking out to the flywheel but no cranking. I tried to rock my Jeep back and forth to see if the flywheel was blocking the solenoid from popping out but no luck. I also tried jumping this new starter straight to the battery and still no luck only the solenoid popping out but no turning over. My battery is only a year and a half old I tried hooking up a jumper just to see and still no luck. Just the previous day the Jeep would crank right over no problems, I can jump start the jeep from a rolling start. I was thinking that it had something to do with my flywheel. Any ideas would help before I drop my tranny tomorrow thanks.
