2002 Sport 4.0L
So my A/C was dead and I think it was the low side schrader valve. I replaced it, but when I pulled it out it was stuck, and I had to drill it out then use an easy out to remove it. After installing a new valve it is still leaking (a lot) and I believe it is because the valve will not seat properly. When I screw the valve into the socket it sits way low, and is very rough to screw in. So I want to replace the line. Unfortunately there is not a single Wrangler in any junk yard near me that I have called, so I need to order a new line. When I look online for the part, all the replacement parts I can find have the port in a different place and look like there is a slightly different bend to it. I think it is (OE) Part #:3463631, 55037505AC from what I can find. I found the below diagram with matching port location and bends on-line, but it did not list a part number. I have highlighted the line I need in red. You can also see it in my picture (it is removed and just sitting above where it would go).
This is all I can find online, and it seems to have a slightly different bend near the firewall side, and the port is in a different but still accessible spot.
Did Jeep maybe change the shape of the line, or is this just the wrong part? CarID shows it will fit my car (CarID Link) but I am hesitant to order it since it is shaped different than the old part. Any help you can offer would be very much appreciated.
If someone with a 4.0l 2002 could take a picture of their low side line it may help me identify if the CarID part will fit. Is your charging port near the firewall connector or down near the air box?
