Ok so my A/C has been blowing cool (not really cold mind you) more or less since I bought my Jeep (97 4.0 TJ) a few months ago. It usually starts cool then will get a little colder after a few minutes and be alright.
The last week or so it has also started loosing the cool air altogether and just blowing that glorious Arizona July heat right in my hairy face.
I verified the compressor clutch is engaging (A/C on full, recirculate on, clutch is spinning). I bought a can of A/C Pro thinking the refrigerant would be low (which would indicate a leak but I was hoping a small one the A/C Pro would bandaid and get me thru the summer.)
Okay so per the instructions on the can I put the test gauge on the low pressure port to check the pressure before recharging and the gauge reads in the green indicating no charge needed.
So my question(s) is, does this mean there is no leak? The compressor clutch is working so is there something else that it would most likely be?
I’m guessing it’s time to pay a pro but i don’t want to if there is something else I can/should check first.
The Arizona desert in summer is a less than pleasant place to be without A/C!
