Assuming you've checked all the simple stuff - tires, eng/trans mounts, ujoints, front hubs, etc, and ran it with each driveline removed. And the problem persists...
First off, I'll pass on a tip I recently got from a diff/trans shop we do business with. If you really want to narrow it down, pull the rear axles and carrier. Run it up to the problem speed. There's enough residual lubrication on the pinion bearings for a short test. Right away you'll know if the problem is in the rear axle or forward.
I'm starting to think that the rear axles could be the smoking gun in many of these highway speed vibration complaints. The spec is typically within .003" on axle straightness. You could have a bent flange or the axle is tweaked further in so you have to check both vertically (shaft) and horizontally (flange). These are not things you can eyeball. A machine shop with a lathe is the only way to definitively check the straightness. If it's a minor flange issue, sometimes they can turn it true although the studs would have to be removed.
I've been tinkering with this issue for far longer than most and there are so many variables that affect the severity of the vibration. I will update as I find out more.
