Go to http://www.grimmjeeper.com/gears.html and play around with tire sizes and gear ratios. That's where the charts above came from. You can spend a lot of time there comparing this to that.
What are the other kind of bushings to look for?
For a rigid aftermarket arm you need flex joints on at least one side(a spherical metal ball in the center)
Th
That sounds neat. Is there a special name to look up?
Awesome, thanks. Not bad, looks like 65 ish each for just the joint. I’ll have to call the steel supply to see how much steel is now.Johnny joint is the most recommended on forum. Can look here for an idea of what joint is like and arms.
https://www.rockjock4x4.com/
Awesome thanks. Not ba
https://www.polyperformance.com/poly-performance-forged-johnny-joint-kit-package these guys have a package deal for joint,insert and jam nut
pretty much have a perpetual 10% off coupon too, NL10
Nice. This is definitely on my todo list. Currently waiting on a new tps as the code will not go away. It came with a cheapie, I have oem coming.
And the gears….currently waiting to see if the will swap them for the 4.88.
