- Price
- $23K
- Location
- VA
This build is the result of more than a decades worth of experience with the TJ/LJ platform. I'll state up front that this is not your average build and you won't find anything else close in quality, on 31" tires. If you're looking for something unlike anything else, and built with no compromises, this is the Jeep for you! Others here know my work, which is always focused on meticulous attention to detail.
The explicit purpose of this build was to keep weight down and maintain the traditional look of a "stockish" TJ, without actually being stock. My goal was to build around a 31" tire, for everyday driving, while maximizing ground clearance. As it sits, with a 2" suspension lift and 1.25" body lift, there is 14" clearance at the belly skid and 14" at the gas tank skid. I also built the Jeep with the future in mind. With only a few adjustments, 4" Currie springs and 33" tires can be added, which will result in an 18" belly height. Additionally, at that point, 10" travel shocks can be added. During the build process the suspension was cycled more than a dozen times, resulting in tweaks made to ensure it can run to full bump with zero interference.
Overall, this is one of the cleanest and well thought out TJ's you'll find. As stated before, it isn't cheap, but no compromises were made. If someone tried to duplicate this build, they would easily be north of $30K. It is rust free, reliable, drives amazing, has no vibrations, and puts a smile on your face every time you sit in the seat and turn the key. Here are details from the build:
2003 TJ Wrangler Sport
- 182K, with automatic
- Full doors
- New soft top
- Added Factory SKIM (For anti-theft purposes)
- Bedrug interior
- Tuffy center console
- Tuffy Glove Box
- Bartact two-tone rear seat covers
- Complete new cooling system
- Complete new A/C system
- Complete new exhaust (Manifold back)
- Complete new brake system (4 wheel disc)
- Complete new HD steering (ZJ upgrade)
- Yukon Front locking Small Hub Kit
- New 31x10.50R15 Mickey Thompson ATZ P3 Tires, Mounted on ProComp 1069 Wheels
- New H&R 1" lift HD Springs, Coupled With 1" USA Made Aluminum Spacers
- Front Currie Track Bar
- Rear Currie Trak Bar, With Currie Re-location Bracket
- Skyjacker Black Max matching shocks, with 8" shock travel
- 4.10 Rear Dana 44 with air locker and 4340 Revolution Axles
- 4.10 Dana 30 with Detroit TrueTrac and Yukon 4340 Axles
- 241OR 4:1 transfer case
- Tom Woods custom drive shafts
- Savvy Aluminum Rocker guards, with Steel Step
- Savvy cable transfer case shifter
-Savvy Aluminum Gas Tank Skid
- Savvy 1.25" Aluminum Body Lift
- Savvy Aluminum Under Armor (Tummy Tuck and Engine Skid)
- Savvy Double Adjustable Aluminum Control Arms
- New 4 hole injectors
- New Oil pump
- New Timing Chain
- New stereo and Speakers
- Auto Transmission Cooler and Temperature Gauge
- Power Steering Cooler
and way more
- Full doors
- New soft top
- Bedrug interior
- Tuffy Glove Box
- New Oil pump
- New Timing Chain
and way more
