Kraken72 Bolt Breaker Supporting Member Joined Jan 4, 2022 Messages 192 Location Louisiana May 16, 2022 #1 Looking for the electrical connector for my ac high pressure switch. Will one from an Xj work? Only thing at pull apart. See photo.
TJ4Jim TJ Expert Lifetime Supporting Member Joined Dec 9, 2015 Messages 3,893 Location Brookings, Oregon May 16, 2022 #2 Kraken72 said: Looking for the electrical connector for my ac high pressure switch. Will one from an Xj work? Only thing at pull apart. See photo. View attachment 330951 Click to expand... I would think they're probably one in the same. Davey's Jeeps could probably do that also, do a parts request. https://daveysjeeps.com/ Reactions: Kraken72
Lou Don’t drink the koolaid Supporting Member Joined Jun 16, 2016 Messages 2,865 Location Long Beach May 16, 2022 #3 Like this? Reactions: Kraken72
OP Kraken72 Bolt Breaker Supporting Member Joined Jan 4, 2022 Messages 192 Location Louisiana May 16, 2022 #4 Going to go check pull apart before I order that one. I despise putting those connectors together.
Lou Don’t drink the koolaid Supporting Member Joined Jun 16, 2016 Messages 2,865 Location Long Beach May 16, 2022 #5 Kraken72 said: Going to go check pull apart before I order that one. I despise putting those connectors together. Click to expand... Do you just need the connector body? Are your pins in good shape?
OP Kraken72 Bolt Breaker Supporting Member Joined Jan 4, 2022 Messages 192 Location Louisiana May 16, 2022 #6 Pins are a no go. Wires got chewed up somehow right at end of plug. So need the connector and and enough wire to splice.
