Accelerator Pedal Knocking
JMT
The Jeep Guy
Washington
Most annoying rattling noise as I go down the road over bumps. Am I missing some piece? There is some play in the hinge. It’s driving me crazy! I can duplicate it by fooling with the accelerator by hand with the Jeep just sitting there not running. The bracket attached to the firewall is tight.
Reactions: MountaineerTom
JMT
JMT
The Jeep Guy
Washington
It's super annoying. Does anyone else's accelerator rattle when you move it around with your hand? That might help me figure it out.
MountaineerTom
South Carolina
I need to check this out. I've had a noise in/under the dash area ever since I've had my Jeep that I haven't been able to track down. I was hoping when I replaced my heater core last year that I would find it. I didn't. LOL
Do you feel the pedal move when you hear the noise?
Does it sound kind of metallic sounding?
Reactions: JMT
Zukey14
Lambertville Michigan
Looks like you have 2 wires (maybe for an amp?) running behind the plate that bolts the petal to the firewall which wouldn't allow those bolts to be tightened down all the way. Take the two nuts off, the plate and petal should all come off and remove the wires (zip tie them to something else) then put it back and tighten it down. I bet it will stop.
Hook_62
"The Exception"
SE, PA
what's that cable going under the hinge bracket? is it holding the bracket up off the floor?
Hook_62
"The Exception"
SE, PA
just walked out and checked mine, no rattle.
92851
Reactions: JMT
MountaineerTom
South Carolina
I just checked mine. Is this what yours is doing? I’m not sure if this is the noise I hear when driving or not. I haven’t driven it in a few days, but I’ll listen for it next time, and see if I can feel it in the pedal. I can see the bushings moving some.
JMT
JMT
The Jeep Guy
Washington
Yep, that's the sound alright, that's exactly what it does, so annoying, rattles everytime I hit a bump.
JMT
JMT
The Jeep Guy
Washington
The bolts were tightened down before I ran the winch and amp wires behind it. I can't remember why I didn't just run them below, maybe they were too short. At any rate, they are not interfering with the two nuts being tightened down. Thank you though! Good thought
JMT
JMT
The Jeep Guy
Washington
Thanks, I'm looking at your picture trying to see if anything is different between yours and mine. It looks like behind the orange cylinder at the top, you have a black cap on the metal that protrudes from the top of the accelerator bar. Mine looks like it is missing. Not sure that would make a difference.
JMT
JMT
The Jeep Guy
Washington
As you know, its hard to diagnose when you're driving. LOL. I'm going to try to see if it stops while I've got the accelerator depressed vs just coasting. Also drive it barefoot and see if I can feel the rattle coming through the accelerator pedal. I've about concluded it's not the clutch pedal and it's not the brake pedal, but I can feel it in the brake pedal, but that may be because it's closer to the accelerator and the vibration is being picked up there.
MountaineerTom
South Carolina
I wonder it those bushing come out easily without breaking? Could try wrapping some electrical tape around them to see it the noise goes away. Maybe even tape them a little the way it is just to test it.
Reactions: JMT
JMT
JMT
The Jeep Guy
Washington
It's worth a try! I'll be the guinea pig.
JMT
JMT
The Jeep Guy
Washington
It’s not the accelerator. Red herring. Still don’t know! Geez
JMT
JMT
The Jeep Guy
Washington
Turn the music up really loud to avoid this sound
Reactions: dudehitt
