I'm swapping a set of JT wheels onto my Wrangler. The stock TJ lug nut thread pitch is a 1/2"x20 (19mm socket), while the JT is a 14x1.5mm (22mm socket). The adapters used for the swap are all 1/2"x20. When using the JT wheels on the adapter, the conical base on the TJ lug nut is to small. Does anyone know of a 1/2x20 lug nut that has a larger conical base, like the stock 14x1.5mm ones?
