Ok I'm gonna try and make this as simple as possible lol. Seriously, don't let this intimidate you, it's just adding three wires. This is all to help explain where those three wires go; two in the engine bay, and on under the dash. The only wires that
should be missing are the ones that come directly off of the CC servo. I have highlighted these wires.
FIG. #1
The bottom left square represents your CC servo, labeled
SPEED CONTROL SERVO. There are three wires I have highlighted, they are the ones that you need to add. Two of those wires go to one of your PCM (
POWERTRAIN CONTROL MODULE) plugs, and one of them goes through your firewall and to a connector (
C107) under your dashboard. There's a fourth black wire (
BK) that goes to ground.
There are two wires coming off of your CC plug that go to the PCM:
Cavity #1).
Tan and
Red (
TN/RD) which travels to your
PCM C3 plug and goes into
cavity #4.
Cavity #2).
Light Green and
Red (
LG/RD) which travels to your
cavity #5.
FIG #2
Here is a picture and list of all the wires going into the PCM C3 plug. I've highlighted the two wires that need to come from the CC servo and into the PCM C3 plug. Note that the colors are labeled the same as in the first diagram. There are numbers on each side of the plug. 1, 11, 22, and 32. These are the cavities going from right to left. So the top row (from right to left) is 1-11, the middle row is 12-21, and the bottom row is 22-32. The bottom two rows are irrelevant to what you're doing, but this is to help you understand better how to locate the right cavity. There are also small numbers on the plug marking each cavity.
FIG #3
The last wire that needs to go from your CC plug is a
Dark Blue and
Red (
DB/RD) wire that will pass through the firewall and go to your
C107 plug under the dashboard. This plug is right around where your left knee will sit and is very easy to access. This wire carries a signal from your brake lamp switch to your CC servo but is separated by the C107 plug. The wire is
most likely already going from the brake lamp switch to the C107 plug, so you need to continue that wire to the CC plug. I would just cut the wire at the C107 plug and add it to the wire you have coming from the CC plug.
FIG #4
This is your
C107 plug. The
DB/RD wire comes from
cavity #3 on your CC plug and goes to
cavity C3 of your C107 plug. You can see how the plug has rows of letters and numbers. This is how you locate the correct cavity. Each cavity is marked in very small letters to help you identify the correct one. As I said above, I would cut this wire off behind the plug, and add splice it to the wire you have running into the cab from the CC plug.
My only other advice is when you go to the junkyard and cut off a CC plug, cut back the harness and get
as much wiring as you can, all the way back to the PCM plug/firewall if possible. If not, cut off a PCM plug and try to keep some wiring on it (like 3-6") to splice on to. You'll want two of the metal connector pins at the end of each wire to remove from the cavities in the junkyard plug and insert into the cavities on your PCM C3 plug.
Ask any questions you need to
I'm hoping others can learn from this too as it's a fairly common question.
