Adjustable track bar with relocation bracket?
bleb88
biloxi
I am Currently running a 3” lift and would like to install 1.25” coil spacer lift. I was looking at adding adjustable front and rear track bars when I install the spacer lift. My question is do I need a track bar relocation bracket if i plan on installing adjustable track bars?
Only if you also install a dropped pitman arm. But only if you do that.
You may need one on the rear, depending on your pinion angle.
Dead on... The adjustability feature takes care of the offset but making sure that you get the clearance in the back matters.... That's where things get tight.
Thanks guys! I will grab a bracket for the front and rear just in case.
All you want is the CV style track bar bracket for the rear. Leave the front alone. Use Rock Jock adjustable track bars.
Reactions: D M
Can you show that type bracket or link it...new term to me also. Thank you.. learning.
It's the angled bracket rather than the straight one.
I'm assuming the op is addressing the driveline angles that come with a 4.25" spring lift.
Thank you. New term for me there sir
