I was dialing in my pinion angle this weekend after my tummy tuck. I followed the "rules" and removed one upper arm (passenger in this case) and used the driver's side to get the pinion angle just right. After that, I started working on installing my angled trackbar bracket. Well, wouldn't you know, the driver's side UCA had to come of to access the bolts. For some reason, I had to extend my passenger side UCA to get the pinion angle back. I lost a couple degrees between removing the driver's side, jacking the rear up, lowering it down, and trying to install the arm again.
What gives?
What gives?
