- Joined
- Oct 18, 2016
- Messages
- 24
Alright guys. I've got a 2003 Jeep TJ Sahara with the 231J transfer case. Several months ago a noise started to develop. It sounds like bearings that are completely shot. Theres a really loud sound inside the cab. I pin pointed the sound to the transfer case when I got underneath it while the rear wheels were off the ground. There's a bunch of noise that sounds like several problems within the transfer case. It also sounds like the chain is really loose as well. My 4x4 didn't work when I first got it due to bent shift linkages. So I'm not worried about that right now. I purchased a bearing and seal overhaul kit and a new chain. I was looking at ordering a new range fork too but wasn't sure if i should replace it too while I have the case popped open. The jeep still drives just fine. So I don't believe the main output or input shafts are damaged. Ive got the general idea of what to do to rebuild it but would like any and all advice. Thank you.
