I have removed my rear rubi 44 and put in an RJ60 with an Elocker. Will be doing similar for front. For those of you that have transitioned from factory rubi locker to ARB or Eaton elocker, what did you do with the existing rubi locker wiring harness and vacuum lines?
At this point, I have removed the entire front and rear harness and lines between axles and pumps, but I still have the connectors where the wiring spliced into a larger bundle by the transfer case. What should i do from here?
