after driving highway speeds, RPMs dropping out at stop light
Well, I replaced the IAC with a MOPAR unit. It still does the drop out, but not as violent. any other thoughts?
Any check engine lights or error codes? It sure sounds like a vacuum leak to me.
Did you ever check the manifold gasket? Mine was doing the same thing like I mentioned and it was fixed when the manifold gasket was replaced. I had leaks all around the manifold.
Is it stalling out completely or just low rpm's?
RPMS dropping really low. when I step on the gas it sounds and feels like it will stall out, but doesn't. serious hesitation.
I completely forgot about your fix. thank you. I will try that this weekend and see what happens.
Check your throttle position sensor. I had the exact problem. New tps fixed me right up.
Sent from my SM-N920V using Tapatalk
