Fletcher34
So I just calculated my mpg and I get 12.02
Mainly highway driving cruising at 60. (Stayed on the right lane on purpose). Flat, no hills.
4.0
Auto 32rh
3.73 gears
31" ko2s
52k miles on the odo
That's on the low end right?
Edit: forgot to add this is based on tank filled to max then driven for 199 miles. Light came on and I filled up again with 16.55 gallons. What tire size is the TJs cluster calibrated too? I'm guessing the original owner did not calibrate the cluster 8k miles ago when he went to a slightly larger tire than stock.
I've got your exact tire size setup on my 02 sahara with 148k miles. I'm running a 2" spacer lift and 1.25 body lift and I get 14-16 with mixed driving.
