One of my long time coworkers(30 yrs) from the metal shop side of the shop. Us old timers gotta stick togetherWhoever welded it did a great job! Nice work.
How did you get that bent? That's what I wanted to do with mine, but didn't have any way of accomplishing it...And marked the lower tie ins(?) for drilling and cutting
I bent them on a (type of?) arbor press using bending dies. Not sure if I’m using the proper terminology. Something very similar to thisHow did you get that bent? That's what I wanted to do with mine, but didn't have any way of accomplishing it...
Niiiice! I wish I'd had access to something like that for my build, as it is, I just used a pair of 1/4" thick square washers (that I made up).I bent them on a (type of?) arbor press using bending dies. Not sure if I’m using the proper terminology. Something very similar to this
@Zorba you could use a small bench top press and a v block to accomplish small parts like that.Niiiice! I wish I'd had access to something like that for my build, as it is, I just used a pair of 1/4" thick square washers (that I made up).
Here is what I did on my front bumper ends. I pie cut a v out of the bottom section then heated and bent it up. Welded it together this method kept the radius on the bottom edge consistent. I then cut the end square and capped it. Here is a picture of my rear bumper for you to see options also.Trying to decide what to do with the ends:
-what shape, leaning towards the double bevel
- and how long? Was going to go full width of the tub but I think it would look better shorter.
Here are some views ot my mock-ups
Here is what I did on my front bumper ends. I pie cut a v out of the bottom section then heated and bent it up. Welded it together this method kept the radius on the bottom edge consistent. I then cut the end square and capped it. Here is a picture of my rear bumper for you to see options also.View attachment 313163View attachment 313164
If I *had* a bench top press!@Zorba you could use a small bench top press and a v block to accomplish small parts like that.
Here are a couple pictures I have, I can take a couple tomorrow if you would like, let me know.I really like both of those. My front is a chopped stock bumper.
Could you take a pic looking down and the end of the rear bumper? I’d
Could you take a pic looking down and the end of the rear bumper? I’d appreciate it.
Looks great! The pics you posted show what I wanted to see, thanks.T
View attachment 313185View attachment 313186
Good callI’ve decided I’m going to leave the bumper full length and instead of a 45* bevel I’ll go less, 20-30* I think.
I have a 45 on the front bumper and I like how it looks that’s why I started there. After seeing the rear bumper Nsklj built I changed my mind.Good call
personally I think 45* is too steep in an application like this, but people just default use it because its a common measurement and their speed square comes preinstalled with a 45* in it
Hey nice! I ran a little amber chase light on mine too
Awesome do you have any pics of your front bumper?I have a 45 on the front bumper and I like how it looks that’s why I started there. After seeing the rear bumper Nsklj built I changed my mind.
