2005 4.0 with NGS370 6 spd manual transmission. 231J transfer case is leaking, suspected input shaft seal but when I cleaned it up the issue is a cracked case. JB weld has stopped the leak for a year now but I plan to replace the clutch over the winter and figure that's as good a time as any to swap the transfer case. Lots of used cases out there and want to be sure I'm picking the right one
Read several posts on short/medium/long shafts and the consensus seems to be any of those is compatible with my transmission. Question is what is this on my output shaft? Some sort of balancer? And more importantly do I need it? If so do I need to find a case that has one, or worst case can I swap mine to whatever case I buy?
