There is a body mount near the radiator that has nothing to do with mounting the radiator.
Sorry- it would have been more accurate for me to say the grill body mount.I've had my front end apart recently and replaced the radiator at that time. Your description of "Radiator Body Mount" bolts is ambiguous to me. Can you post a picture? I can only picture the 3 bolts/screws on either side that mount the radiator to the front nose clip. Torch heat would be really difficult/impossible on those...
I'm pretty sure I know what you meant, I was really just saying that for someone else.Sorry- it would have been more accurate for me to say the grill body mount.
It is a nut plate in a box. There are generally some small corners that are open you might get a straw into and soak it that way.Is there any way to access the threaded portion to spray with oil or heat with a torch?
Yep! Saw those exact holes you are talking about and blindly sprayed it in the best I could. Fingers crossed...It is a nut plate in a box. There are generally some small corners that are open you might get a straw into and soak it that way.
