So that answer is maybe. These mechanical pumps are more or less gravity fed, and can't do much "sucking". With the line unhooked at the pump and a 1/2 tank or so of fuel, the line should be free flowing, and you should be able to easily get a siphon started. (Be aware, I had one I couldn't get stopped) Start there, make sure the tank-to-pump line is clear, or whatever your supply line is, and all rubber in the line is in good condition.
After that, we're at the pump. You can test the pump to see if it's in good condition. If it is, mount the pump and hook up the supply side to see if you can get fuel through it.
If you can't, then I’d start looking at the cam/pushrod. I'm not familiar with these engines, I don't know if the pump runs on the cam directly or uses a pushrod like a SBC/BBC or MoPar B/RB (those are what I'm most familiar with). If it can push fuel through, then you're down to pump-to-carb.
What problem(s) were you originally having?
It runs on the eccentric mounted on the cam directly.
Took long time to start after sitting.
Then when it had been run, it ran great started easy even after a couple hours. Week later took time.
Then I changed oil, smelled fuel (so diaphragm most likely leaking).
Then after sitting just won’t get fuel to clear fuel filter, I know it’s not pumping. To filter.
