Anyone run a ProRock 44?
04RubiOR
Redmond, OR 97756, USA
I’ve got a 04 Rubicon and 35’s stock axles. Want to go with 37’s eventually. This is my DD. Can’t afford a $7000 front Dana 60. Curious if anyone can recommend a Dynatrac ProRock 44? I understand you have to reuse your stock knuckle and outer axle shafts. I have the Vanco big brake kit which came with a nodular iron knuckles. I also understand you have to use a jk Dana 44 r&p and locker. If I upgrade to chromoly shafts outer and inner, plus jk Dana 44 r&p (I understand them to be stronger than tj Dana 44) this seems to be much cheaper then a Dana 60. Is the benefit in strength worth it? Will it run 37’s no problem? Thanks for any feedback.
