No, it highlighted the precise brake bias and why if you reverse it, it won't work well at all. You are watching an exact demonstration of why the front brakes are much larger than the rear brakes, typically by twice and how that works. If you put the rear brakes on the front and the front brakes on the rear, what you see in the video is how they would work going forward. The fronts would spin and the backs would just lock up and drag easily at all but the most gentle of stops.
You turned the back brakes into the front brakes and the front brakes into the back brakes by reversing down the hill in 2wd. Now you fully understand how to prevent that from happening, why it can't be "fixed", and how brake bias and component size works.
