I have an interesting situation. I went to install my ARB locker into my Ford Explorer 8.8 differential. When I opened up the diff and pulled out the LSD I saw a mark on my ring gear that I thought was a broken tooth. I previously had 4.88 gears installed about 2 years ago. I picked up a gear set from US Gear and proceeded to install them with the help of a knowledgeable friend. We got them installed and when I went to remove the cross pin, it hit the inside of the ring gear. I read online that to remedy this problem, you grind away enough of the ring gear to allow the pin to come out. I called US Gear to confirm this and they do not recommend grinding the gear teeth and suggested a notched cross pin. I then called ARB to confirm using a notched pin and they recommend in their instructions to grind the gears and do not recommend using a notched cross pin. The other route to go, is to install a c-clip eliminator kit. Which I have read on here and other forums, that they are unnecessary do to the thickness of the 31 spline shaft and that if they do break, the disc brake caliper will keep the axle in. After researching this I came to the conclusion that there was nothing wrong with my previous ring and pinion and should have left well enough alone. I guess my question is, what would you guys do to handle this? Grind, notched pin or c-clip eliminator? If anyone needs to see pictures, I can add them.
Thanks,
Igoo65
Thanks,
Igoo65
