It's my understanding that the twin one is just 2 wired together by ARB.
I do like the idea of the twin, but for the price, I have a gas powered air compressor that I use with equipment so I don't burn up the ARB, but I have used the ARB single air compressor to blow out a radiator and it worked fine. It airs up tires, etc, but it's slower. The gas powered alternative is a pretty easy choice for me, because I just hook up a trailer with a bunch of stuff I need for the tractor(s) and can put the air compressor on that, but for most it's too much, but it will run real air tools, etc. However I've switched mostly to battery powered tools, so I don't use the air compressor as much.
Carry a spare fuse btw. I got into some weather and the somehow some of the wiring got in water and blew the fuse, which was annoying because I needed to air up. I put my air compressor under my seat, because I've got a bunch of stuff under the hood now. You may be able to fit the twin there though. I do carry a spare tire inflator, because I inflate tires pretty often so I was ok, but it is deep in my gear to get out and use.
For better or worse, here's my install in my Jeep.
