I'm in the middle of swapping my stock axle to a Dana 30 HP and cannot for the life of me get my springs in and LCAs bolted up at the same time. I had the axle aligned and loosely bolted in, managed to get the passenger side spring in, but found there was no way in hell the driver's side of the axle would then drop anywhere near where I needed it to get that spring in. Finally I unbolted the LCA on the driver's side, which caused the axle to drop to where I needed it but also move back about 1". I got the spring in, but then there was no way in hell the LCA would line back up with the bolt hole in the lower mount. Fast forward a few hours of yelling at it, a night's sleep, and I decided to use my brain to work the problem, which is when I discovered this:
have no idea who makes these lower arms. They're beefy as hell and went in about 12 years ago when I bought a lift second-hand in law school because I couldn't afford anything else. Never noticed an issue before but it appears that they're too tall and are interfering with the axle when it tries to drop. When the shock mount contacts the top of the LCA, the axle can either roll forward (which it can't with the UCA in) or can't drop any further.
Anybody had this problem? Is there a solution other than new control arms? I really didn't intend to add adjustable lowers at this point, but it looks like I may need to just to create more clearance between the axle and control arm. Any other suggestions?
Btw: the lift is a Zone offroad combo kit with a 3" suspension lift, 1.25" BL, and 1" MML. The BL and MML are installed (mostly... ask me why I hate the location of the AC compressor). Steering is all removed, so the only parts in the axle equation are the control arms and springs.
