As I are a trucker, I think all y'all suck at driving.
As I are a trucker, I think all y'all suck at driving.![]()
Today was just a short workspace cleaning day. Hopefully will be pulling out of there next week but we will see.
After you finish the Jeep, here is your next project
I’ll try and catch this up on some less exciting events.
I’m working fast on this thing to take advantage of good weather for wheeling. So before I put the Jeep down for the project I dropped it off at the muffler place while I was working to have them fit whatever muffler they could over my skid with a turn down off of it. That way I can run it when I’m done with the midarm and build the tailpipe when I have time
Something that hung me up a few days was when I cut my stock LCA mounts off, I found the rust there on my frame was pretty bad. My Jeep wasn’t always an Arizona Jeep, it was in Wyoming a few years before me. The frame is in really good shape everywhere except for that spot right above the rear LCA mounts… I’m guessing some salt got trapped there from Wyoming and kept corroding. The sides were in good shape so I just cut the bottom out up to where the frame was thick again and welded in a new bottom and grinder smooth.
Looks like you've been taking grinding lessons from Stumpy.
Inspiration goes both ways![]()
He needs this in 4.5" and 5".
https://www.amazon.com/dp/B08VJCQ1P7/?tag=wranglerorg-20
Then he needs these in 5" in both 36g and 60g. If only one, get 36g.
https://www.industrialgeneralstore....6-6-in-x-7-8-in-die-600t-25-inner-100-ea-case
For making your own 4 link rear that has the right frame side seperation, how far off is the genright 4 hole bracket? From their website It seems like it’s soo much but it looks about the same height over the top of the frame. For the front parallel 3 link could you also use genrights 3 link but swap the upper frame mount with an axle side tower to get the seperation there too? Just thinking of options as op is doing. I’m dying to get on the mid arm and not my hopping but don’t have the money as a married college kid yet.
